given they want to do relatively heavy 3D graphics on IC to show the "preview" features, and they don't have any actual substance just the eye candy, makes perfect sense to only update the cars that could show the aforementioned eye candy.You would think the earlier fsd supporters should be the first to get the upgrades.
Some might! I'll have replaced mine by then... Also probably have a Cybertruck....Do you think we'll see humans on Mars before the MCU2 upgrade?
I bet you Starship has MCU1.
I would *definitely* take it to the SC and get your concerns *documented* with an appt. The spontaneous restarts and whatever slowness/glitches that are happening. Let them know you are very concerned about the well documented eMMC failures. REASON: because even if they don't want to replace it (MCU/eMMC) now that if it completely fails in Oct you can document that it was happening while still under warranty.What should I do?
Here's my situation. Took delivery of a CPO (back then, it was still CPO) 2013 (pre-AP) Model S 60 in September of 2016 with 4 years of warranty.
My MCU is still working with occasional glitches. Maybe once a week there's a major enough glitch that it either spontaneously restarts or I have to force restart.
It's still 3G, which is fairly slow but works well enough for music/podcast streaming. If I have a lot of patience, I can sometimes even get websites to load in the browser.
My warranty expires in September.
- Do I just hope for a eMMC failure before then?
- Is it helpful to have the SC log minor glitches so there's a record of failures while under warranty?
- What about the cellular connection -- carriers are deprecating 3G; if Tesla doesn't upgrade the connection to LTE, won't they lose the ability to push OTA upgrades to me?
What should I do?
...MCU is still working with occasional glitches...carriers are deprecating 3G
well, I am not so sure about it I mean sure there's certain capability but perhaps it falls apart wih more than a couple of objects?The v1 IC and MCU are perfectly capable of displaying the 3d objects. The assets have been the for a little bit now. It would be laggy though like everything else is on the MCU1/IC combo...
I noticed the avatar car model looks more detailed on ic2, as if there's a prerendered flat image on ic1 and actual 3d model rendered in real time on ic2.
Yeah, I don't doubt they are better on 2 but given that we had stop signs and lights showing on MCU/IC1 some months ago I'm pretty confident they could make a version of the visuals work. Might be crappy but....well, I am not so sure about it I mean sure there's certain capability but perhaps it falls apart wih more than a couple of objects?
well, they did get to the eyecandy from the old way of just displaying the detections without any positioning information. What's the utility of that? Next to none. (while we are at it - why not show all other detections then?)Yeah, I don't doubt they are better on 2 but given that we had stop signs and lights showing on MCU/IC1 some months ago I'm pretty confident they could make a version of the visuals work. Might be crappy but....
Not saying not to show positioning, IC1 does vehicle positioning just fine. It's laggy but it works. Just use 2d images if that's a limitation.well, they did get to the eyecandy from the old way of just displaying the detections without any positioning information. What's the utility of that? Next to none. (while we are at it - why not show all other detections then?)
I mean they are going to have to figure it out if they don't intend to retrofit every MCU1 AP2-2.5 vehicle anyways
Sure, but it won't be "FSD" at first... It will be another L2 driving aide with nags, as such it would be reasonable to expect to see what the car is going to want to do. Otherwise it would be pretty nerve racking in the cityWhy? FSD doesn't need to display anything...
Do : Drive the car and enjoy it.
Purchase LTE to Wifi (aka Mifi) device and keep in the car if you dislike the Tesla 3g speed.
Save up a few $$ for MCU1 swap at Tesla, or perhaps 3rd party flash swap out depending on the issue (flash worn out or MCU1 itself failing).
