Back on Post #4926 of this thread, I had this idea. I thought it would be simple. I would open up my car’s dash, remove the MCU and unplug the two USB cables going into the back. I’d add an 18” Male/Female USB Type-A cables and put the MCU back. Well, I did and I didn’t. I wanted to give you guy and update. I have some tweaking to do so I like how it looks. But this is 98% of it.
It was my intent to intercept my USB signal/cable running to the back of the center console and insert a couple of USB 4 port hubs and continue the signal on to the back of the center console. Sounds easy.
I ordered parts, some turned out to be wrong. I need different cables and an adapters. Here’s what works.
To try and make the explanation simpler, I am going to name my cables.
Old USB cables: Original cables plugging into and running from back of the MCU to the back of the center console under the armrest.
Mini to USB Female: USB Mini Male to USB Type-A Female
Short USB-C: USB Type-A Male to USB-C Male.
Mini Adapter: USB Type-A to USB Mini Female Adapter/converter
18” MF Cable: USB Type-A Male/Female extension cable 18” long
I unplugged the Old USB cables. These turned out to be USB Mini connectors. MCU is female, cable end is male Mini. I had a couple of male Mini to USB type A male adapters. Plugged those in, then used two 18” MF cables and threaded these to the bottom of the MCU to the cubby opening. Instead of this way, I recommend using a simpler method. Use two Mini to USB Female cable. They plugs directly into the MCU and a female end is ready for the male connector of USB hubs.
First hub: I use one of the two 18” cables from the back of the MCU and plug the first hub into it. I moved the Old USB cables down to the cubby opening. These are going to be plugged into one of the two new hubs. But first, I need two Mini Adapters so I can plug each of the Old USB cables into a hubs. This will send the USB signal back to the center console USB ports. I have a SSD in the glove box for my TeslaCam and Sentry, so I plug Short USB-C cable into the hub and the SSD enclosure.
The first hub under the cubby is powering the USB ports under the armrest and powering my SSD in the glove box. I have one left over USB port on the first hub.
Second hub: The center console has an opening, small hole at the end under the cubby. I threaded third 18” MF cable through the hole and out of the console up under the cubby opening. I plugged it into the other 18” MF cables coming down from the back of the MCU. Inside the center console, I plugged the second hub into the new cable. Now I have four USB ports from the MCU inside the center console for whatever I need, such as a wireless charger and Alexa Echo Auto device.
I used different hubs to make it simple to recognize which cable went to a hub. Here’s a list of the different items I used. I do not receive compensation for links to Amazon. These are examples and pictures at the links.
# 1) Mini to USB Female: USB Mini Male to USB Type-A Female
https://www.amazon.com/StarTech-com...i+to+usb+type+a+female&qid=1593312715&sr=8-10
# 2) Mini Adapter: USB Type-A to USB Mini Female Adapter/converter
https://www.amazon.com/Electop-Pack...ni+to+usb+type+a+female&qid=1593312909&sr=8-2
# 3) 18” MF Cable: USB Type-A Male/Female extension cable 18” long
https://www.amazon.com/gp/product/B01JSI12XI/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
# 4) Short USB-C: USB Type-A Male to USB-C Male.
https://www.amazon.com/gp/product/B07K24TKL6/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
# 5) USB 3.0 4-port hub
https://www.amazon.com/gp/product/B0773HSCBW/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
# 6) USB 3.0 4-port hub
https://www.amazon.com/gp/product/B076Q43SPC/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
#7) 2-Port Dual USB Male to Female Flush Mount
https://www.amazon.com/gp/product/B01MY1WDIU/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I am thinking of adding this #7) flush mount two-port adapter if I can find a suitable place so it’s convenient. It will plug into one of the hubs.
You don’t have to use a SSD for TeslaCam/Sentry. You could route the USB cable to the glove box and plug a flash drive or SSD media adapter there. The bonus security of hiding it in the glove box is, you can leave an old or small flash drive in the rear USB ports under the armrest for decoys. Leaving something for someone to find easily increases the security of the one in the glove box.
If you wanted to do this project but didn’t want to remove your MCU, the # 1) Mini to USB Female cables, could be added to the car while the techs are performing the MCU2 upgrade or MCU1 replacement.
You would need to procure the cables and have them available when you take your car in to the SC. I would recommend leaving the cables readily available with special instructions as to what you want the techs to do, i.e., remove the two USB cables and insert these #1 Mini to USB Female cables and route your Old USB cables down to the bottom behind the cubby. Donuts or pastries would help and hope for the best.
Here's the cable end that was plugged into the back of the MCU. "Surprise - I am USB Mini not USB Type-A"
