Correct. Even if your car has physical USS (disabled) when you replace the bumper they will give you the same one as the USS-less cars. Also, ensure that you have the latest firmware, which is part of maintenance anyway.or, they disable uss but use the same bumper as there is nothing to change, just to cover holes
Bumpers are just high strength molded plastic. However, that is one of the items that manufacturers use to affect the profit margin because it is relatively cheap to make and it sales a lot. Now, without USS, they will sell even more of them.
It is similar logic for software “inventory”. By disabling the USS they do not need to maintain two separate code bases - less coding and testing.
Add to the above the Tesla Vision dogma and they have every reason to disable USS as soon as possible.
