More details:
How did I come up with 89.5% SoC (on the unlocked scale) as the charging limit for the 60?
First, some continue to refer to the 60 as having 80% of the capacity of the 75. This ignores that Tesla uses 60, 70, 75, 85, 90, etc. as designations rather than accurate quantifications of capacity. I believe a more accurate way to compare capacities between the 60 and the 75 (since they have identical hardware, weight, and battery packs) is by EPA rated range. (210 vs. 249 and 218 vs. 259) These two ratios are virtually identical, and imply that the 60 is allowed to use 84.25% of what the 75 can use. Therefore, the 60 is locked out of 15.75% of the actual usable capacity of the battery. If the locked out portion is distributed 1/3 on the bottom and 2/3 on the top, then the 0% level in the 60 is where the 5.25% level is in the 75, and 100% in the 60 is at 89.5% unlocked SoC. BTW, I don't actually claim the level of precision implied by computing to hundredths of a percent, that's just the way the math comes out. Also, all of these SoC figures are as reported by the UI, not the presumably more accurate ones only obtainable with TM-Spy, CAN readers, and the like. Someday, I may try to get one of those, but for now I'm trying to see how far we can get with *publicly available* information. Still more to come.
