My question is seeing how you guys are just tucking wires in to get it in there. Are there any concerns for the side airbags?
If you are talking about tucking the wire in the trim along the sides of the car from the front to the back, there is plenty of room for the small cable without interfering with anything. You don't even need to remove the trim...just slip a spudger in there to form a little gap, then stuff the wire in the gap.
Well, I finally got my cameras installed, but not without more problems. First of all, my replacement rear camera cable came with the two angled plugs instead of having a straight one for the rear camera. This certainly made it more difficult to get it though the rubber boot to the hatch, but I got it done. I also had to drill a slightly bigger hole than planned in the hatch, but I went ahead and did it.
I got the wire routed from the rubber boot to the new hole, but I was having trouble getting the angled connector through the hole (although the hole was big enough). In the process, I managed to separate the cable from the connector...AGAIN! At this point I was pissed. I didn't think I had put any excessive stress on the cable and it still separated. I also decided that I wasn't going to order another freakin' cable, just to have this happen again. So I decided to solder-splice my two broken cables together. It was certainly a pain in the rear since this is a shielded video cable, but I made it happen with plenty of shrink wrap and a piece of aluminum foil for added shielding. It's ugly as sin, but just like the siliconed-hole in my hatch, all the ugliness is tucked away in plastic trim.
So after many cuss words and several hours of work, I have the rear camera installed. I fire up the phone app to align the camera, and I realize that the image is upside down. I didn't think this was a big deal because my previous, sub-$100 dash cam had an option to invert the image in the software. Blackvue, however, seems to lack that option. Does anybody know if there is a way to flip the image, or am I going to have to flip the camera instead?
