?Drop off of rate of charge at Supercharger St Leonards
Discussion in 'Australia & New Zealand' started by Dborn, Jul 11, 2019.
  1. meloccom
    meloccom Moderator Aus/NZ
    Sydney Australia
    Just saying based on what is happening in Europe there may be a setting in the modified Superchargers to give the CCS2 cable priority.
  2. Dborn
    Dborn Confirmed
    Sydney, Australia
    That sucks!!!!
  3. m4rtin
    m4rtin Member
    Sydney
    I’m guessing the priority for M3 is only at sites with mixed single and dual cable SC. Therefore trying to keep the only ones the 3s can use available. No idea if true though but would make more sense than a sweeping 3 > S or X
    • Disagree x 1
  4. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    I think the M3 priority stickers are just those sites with incomplete cables. Ie if you can, you should park your S/X in a stall without a CCS cable.
  5. Dborn
    Dborn Confirmed
    Sydney, Australia
    Have just charged to 90% on a regular PowerPoint and mobile cable. My range is unchanged from 7/3/19 when typical was 344 and rated was 430. On 26/5 Typical was 325 (no record of rated kept for this date). Today 342 and 428. Within the limits variability i expect. So, it is just the charge rate that has been affected for me.
  6. Mark E
    Mark E Member
    Sydney NSW
    I haven't supercharged since the last update but note that my 90% charge is consistently at 344-345 typical on my S85 which is the same vintage as yours.
    Have you tried to supercharge at another location - ie one that isn't 5km from your home?
  7. Dborn
    Dborn Confirmed
    Sydney, Australia
    No. I guess i need to find time to go to Broadway and try.
  8. Jays200
    Jays200 Member
    Perth, Western Australia
    Maybe battery pack temp at time of charging is a metric that needs to be included.
  9. Blue heaven
    Blue heaven Fair Dinkum Tesla
    South West Australia
    We conducted another supercharger session yesterday at Eaton:
    Same stall as previous charge sessions
    No other vehicles charging as per previous charge sessions
    Same steady 100km plus drive to site
    Similar outside temps
    No CCS2 cables attached
    Car with less than 30 lifetime supercharger sessions.
    Charging from 20% to 70% took 36 minutes the same as previous post software update session, pre-software update session took 29 minutes 20% to 70%.
    Footnote: the charge rate was lower at 20% but tapered off less at a higher percentage.
  10. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    This morning after 1hr drive to St Leonards.
    Charging at 24% started at 82kW, then progressively tapered from 29% down this far at 41%.
  11. smithy
    smithy Member
    Sydney
    Yeah that's pretty poor. Battery would definitely be up to temp after 1 hr drive. Something weird is going on with St Leonards. I'll be there again on the weekend so will see what happens
  12. Dborn
    Dborn Confirmed
    Sydney, Australia
    Went to Broadway today. Charge rate is no different to St Leonards. Spoke to a hire car driver who confirms the rate of charge drop off across the fleet of hire cars following a software “update” last month. Sneaky as I said before.
  13. mrpseudonym
    mrpseudonym Member
    Sydney
    12E363CE-446F-449B-AA01-0909DCE9B1F1.jpeg 13FDDF19-E78A-4F5B-A0CC-D1DEA78569EE.jpeg 3B512137-1EF5-4E51-8056-CDAE1610BE09.jpeg Yes, confirmed its not just st leonards. Charged at Goulburn superchargers today.
    Arrived at 20% charging started at 100kwh but quickly decreased. Ended up at 22kwh. Not very Super..
  14. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    To be charitable, if Tesla has found that previous higher charging rates were causing too much battery degradation, I'd rather have this reduction in charging rates than shorten the battery life.
  15. Dborn
    Dborn Confirmed
    Sydney, Australia
    I remain suspicious that this is a cost cutting exercise. Slow speeds is a disincentive to use the superchargers. My range has not been reduced contrary to the experience on the USA thread on this site.
  16. meowsers
    meowsers Member
    Australia
    I highly doubt this is some vast right wing conspiracy to make you avoid chargers. If Tesla really wanted to slow people while charging, they could do so via the software of the chargers themselves.
  17. Dborn
    Dborn Confirmed
    Sydney, Australia
    I am specifically referring to those of us with free supercharging for life. Everyone else gets charged...
  18. PJF000
    PJF000 Member
    Australia
  19. meloccom
    Sydney Australia
    I’m speculating, and that’s all we can do, that this recent reduction in Supercharging speeds is a safety measure as well as a way of getting these older batteries to the end of their 8 year warranty without issues.
    As to the Supercharging for life, I’ve always thought that was unsustainable and that Tesla would be forced to wind it back. NRMA have made the same error with the rollout of their fast charging network and will eventually be forced to backdown and charge even their members as the numbers of EV owners rise and the cost become significant.
    However one thing I won’t do is apologies for taking longer at a Supercharger when Tesla have limited my car. This may become an issue at times of congestion at Superchargers during holidays.
  20. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    Agreed, if you need to get to a certain range before leaving it shouldn't matter how long that takes, especially since the rates are reduced.
