When you say immediate, you mean the car makes a lane change without notifying you at all? My car always puts up a blue banner at the top of the navigation route info saying "Upcoming Lane Change - Press Here To Cancel", so I know it's going to be changing lanes soon. It will usually give the reason too, like "For Route" or "For Faster Lane", etc. If I can see there is some congestion up ahead, usually before a freeway onramp, I just initiate the lane change early, usually before the blue banner, or just after the banner appears. If I get a speed based lane change notice, and I know it's going to be a problem with congested lanes ahead, or the route needs a turn, I disengage the system and handle the turn myself, then re-engage.Probably different road conditions. Here, the lane changes are immediate, and you have to swerve it back to prevent an erroneous lane change.
For me, I have set my Tesla to ask for change lane before doing it, which helps on any surprises and also staying the lane since the majority of the time if I am using FSD I do not like changing lanes unless I am exiting the road or there is a major slow down on the specific lane.
This setting does not apply to FSDb on surface streets.
I don’t think it even changes the notifications or warnings when in FSDb.
I think the 9k is in CA ?Looking forward to seeing the real world stats for 2022 in California. I'm guessing the accident rate for driverless Waymos is significantly less than 1 per 9,000 miles. haha.
Their published data for Chandler says they were hit once during 65,000 miles of driverless operation.
The human vision system is pretty spectacular compared to FSDb. We can differentiate a vehicle's path, velocity, and know how to respond on the fly. FSDb, not so much but it still needs to make quick decision so sometimes it's wrong. The side view B pillar cameras are low performers when estimating a target vehicle's velocity, range, and path.We have a lot of median separated four lane roads in our neighborhood. There are lots of instances where cars coming into the median area to prepare for a merge are assumed to be existential threats with very hard braking. Interesting problem, when you think about it. A car moving quickly into the median from one side of traffic COULD just continue and ram into you, but we humans assume other drivers will do the right thing. FSDb just sees it as a car moving quickly at an angle and speed that could create a crash if it didn't stop in the median area.
Seems to be an overreaction in the coding that corrected the tendency to not use turn signals when moving into a turn lane.Certainly there is a LOT of unnecessary blinking and I would disengage if there were any significant traffic around, where it would be confusing or a hazard to other road users. But no one is going to be using FSDb when there is significant traffic, anyway. So not really a big deal.
I don’t even know what that means lmaoEverytime you post, I think you are from Afghanistan ... and then surprise
Who said anything about politics?It shouldn't surprise at all. Being empathetic should not be tied to political affiliation.
I’ve also seen the location of the car not matching up with nav on 25.1 & 25.2. This was an issue I’ve seen way back on 10.3.X as well, and it really screws things up.I was able to take 25.2 for my standard commute today.
On the way home it got pretty close to being pretty if I exclude the first few miles.
Highway was really nice, no late braking etc.
For the first time ever it managed to take the double left traffic light. Of course it started in the right lane, moved in the left lane for the corner then immediately back into the right lane, at least it made it. All previous attempts had failed.
It still took way too long when going from a 55mph to 40 mph speed limit, I'm amazed it still does that. Oddly it seemed to figure it out and annoyingly used the friction brakes to get down to 42.
All in all, mostly positive.
The start of the drive was appalling. It started out with the Nav showing us at least 3-4 blocks away from actual location. I didn't notice until I'd engaged FSDb and it immediately tried to turn right from the left lane of a 6 lane wide city street. I gave up on FSD immediately and for the next few miles the nav kept insisting that I turn down some other road that was two blocks away.
Even on the highway it was over a block away. Finally after a mile or so on the highway it finally figured it out and I could restart FSD (more accurately AP at this point)
I haven't seen that issue with FSD since the really early versions which is rather concerning.
Curious how the others roads are now.
GPS was inaccurate, it seems. Sounds like it took a moment to lock on.The start of the drive was appalling. It started out with the Nav showing us at least 3-4 blocks away from actual location.
This.GPS was inaccurate, it seems. Sounds like it took a moment to lock on.
Perhaps an easy option for the short term is to get the turn warn pop-up to consistently prompt 15+ seconds ahead of time and if cancelled don't re-prompt for a time. Maybe an exception if a turn is imminent, only in the direction of the upcoming turn. Sounds like some form of "lane change warning with driver option to opt-out" has always part of the design.I can’t really think of another workable solution long
