the week is not overWell since today is THURSDAY and no evidence of 12.4, much less 12.4.1 that sounds as likely as all of us pooling a couple of dollars and winning the $1.2B lotto.
I've heard others say this, but I rarely find that myself. In fact in my case it seems to push the speed limit a bit much, hitting 35 in a 25 zone for example (which, around here, is edging into getting a ticket territory). using Average setting with the smart speed on. The only times I see the car drive below the limit is when I would also (traffic and/or road conditions). I wonder why the different experiences?1. Clearly an issue that they need to fix, but I’ve noticed something interesting with 12.3.3 - it accelerates quite well up to about 5-7 MPH under the target speed then sits there totally content. If I don’t focus on the speed and there’s no one behind me it’s not at all unpleasant to let FSD do its thing. Not what I would do but not dangerous in any way and not illegal.
Do you use the ASSO setting? I have it in the ‘old’ setting that lets me set the max speed.I've heard others say this, but I rarely find that myself. In fact in my case it seems to push the speed limit a bit much, hitting 35 in a 25 zone for example (which, around here, is edging into getting a ticket territory). using Average setting with the smart speed on. The only times I see the car drive below the limit is when I would also (traffic and/or road conditions). I wonder why the different experiences?
I'll remind you Monday since it is sorta like the Dec. proclamation you made that v12 was coming in two weeks.the week is not over
I keep switching back and forth trying to decide which is the LESSER of the two since neither work well. ASSO works OK on some streets but can vary so much on other streets, especially on the low speed end. Max seems to work better on other streets that ASSO fails but it also can be inconsistent. I sure hope Tesla trains hard on getting some consistency in 11.4. Would also love to see the 3 modes reflected in the % of MAX speeds it maintains.Do you use the ASSO setting? I have it in the ‘old’ setting that lets me set the max speed.
how do you clear the mirror fold location?Had this happen after an update forever ago. I just cleared the mirror fold location and then set it again in my garage. Has been solid since. I think there is some uncommon bug which clears or alters driver save data afterban update. Every couple of updates I have some user setting revert. Usually it's benign however. Like changing the location of the blinker cameras.
I asked for this before.Another point I want to add is that I wish Tesla implement FSD Supervised more towards ADAS centric.
I was watching Chuck Cooks video this morning on protected left turn testing. I question the attention the driver need to monitor the car and surroundings during the turn. That is no way to make the user more "relaxed". For me personally, I would just drive to the stop line, one look at the left traffic, if it's very busy, I just relax and do my thing and come back to check the conditions after I think the traffic had passed. But not with FSD, I need to monitor conditions all the time, worry about FSD not making the right move, etc. That's not relaxed driving at all! Not ADAS at all. A true ADAS in this situation would tell me to relax and FSD is not going to do anything until it signals to me that its actively thinking of going ahead again, and I need to monitor its execution.
It should plan the route so that such edge cases are minimized if not avoided completelyAnother point I want to add is that I wish Tesla implement FSD Supervised more towards ADAS centric.
It's on Tesla to test in every situation before release. Standard engineering practice: research and understand the entire set of environmental conditions your design is subject to, and relentlessly test against that. Then check again, and have unbiased peers double check your work, your assumptions about everything, your research, try to poke holes in everything.Another point to consider for those asking “how in the world could they let this version out for wide release???”
From what I’ve seen in the comments, the variability in experiences between users is much greater with this version than it has been with previous versions. Even if we leave @AlanSubie4Life out of it I don’t think we can chalk it up to personal preferences. I don’t know if it’s related to location, hardware configuration or something else but it’s definitely real.
Whatever the reason, if the testers (and Elon) have my experience then it would make perfect sense to do a wide release. If they have others’ experience it wouldn’t.
There's an 'avoid/use HOV lanes' option in the navigation settings. Did you set that to 'avoid'?Is there a way to prevent the car from going into the HOV lane? On FSD, my Model 3 quickly got into the fast lane and then abruptly tried to change to carpool lane. I don't have HOV stickers and I was the only one in the vehicle. I had to disengage quickly and get back into fast lane.
There is no method to madnessI think we need to admit that no one understands how ASSO works and it’s likely a random AI-generated speed target that happens to coincide with what we do often enough to make us think we’ve done something. In reality it’s just the FSD engineers watching cabin cam videos and laughing hysterically.
I noticed today on a road I use all the time, someone started tailgating me, 40 mph speed limit, car was going 42, then sped up to 49 to put distance between us.I keep switching back and forth trying to decide which is the LESSER of the two since neither work well. ASSO works OK on some streets but can vary so much on other streets, especially on the low speed end. Max seems to work better on other streets that ASSO fails but it also can be inconsistent. I sure hope Tesla trains hard on getting some consistency in 11.4. Would also love to see the 3 modes reflected in the % of MAX speeds it maintains.
It’s almost like they should release a beta version the. have a bunch of drivers test it widely to find problems. Oh, wait…It's on Tesla to test in every situation before release.
I am thankful that Tesla releases such great toy (useful when you are careful) for me to play with.It’s almost like they should release a beta version the. have a bunch of drivers test it widely to find problems. Oh, wait…
Yesterday, I drove through a parking area at slow speed ( approx. 8 mph) and saw the P select marker displayed on my front center small screen. Didn't try to park though.Anyone got Park Assist with version .3.3 on their X or S? Haven't had it on my 2022 refresh X forever. Is Tesla ignoring us?
I kind of feel like people have doubts sometimes but I have literally never made anything up here.Likewise, I’ve never had it stop in the middle of a maneuver.
I maintain the two modes have no differences other than the target speed.Do you use the ASSO setting? I have it in the ‘old’ setting that lets me set the max speed.
ASSO works OK on some streets but can vary so much on other streets, especially on the low speed end. Max [Manual] seems to work better on other streets that ASSO fails but it also can be inconsistent.
