sleepydoc
People's experience seems to be highly variable (@Alset2 's post is quite interesting.) I don't know if some people are more sensitive or pickier, if some areas tend to be worse or if some cars just experience less. My guess is it's a combination. My barometer is my wife (and my head.) If my wife is complaining about the car lurching because it's slowing down for no apparent reason then that counts. If my head is bobbing forwards and backwards because the car is slowing down then it counts.Because I have no issue with cruise control? I drive a lot for work and have few if any issues. On FSD beta on occasion it will reduce speed Rarely on questionable side streets but Nothing like you and a few others make it out to be. On AP I can all but take a nap Every drive.
If you have a 'good car,' or are otherwise unbothered by it then good for you (that's not sarcasm, it's a genuine statement).
IDK - what's the difference between phantom braking and the AEB? We don't really know. They could be totally separate or could be the same problem with varying degrees of urgency/severity. My definition of phantom braking is the car suddenly braking for no apparent reason, so that applies in my mind.In my case that I reported here a couple months ago it was the former. The car definitely locked up the breaks as started to rotate slightly before recovering as if nothing happened. I was informed that this is not called phantom braking since it was an activation of the AEB system and not AP. I was driving manually at the time. No AP or TACC active. It scared the crap out of me. Hasn’t happened since. A truck was passing in the opposite direction on a two lane highway at night.
That's nice, but I'm a pragmatist. There is a system that works perfectly (Radar, I'm assuming) and another system they're trying to develop that works worse. They (and you) hope it will work better, but that remains to be seen. It's also possible that it will never be as good. Until then, they are not mutually exclusive. Why ditch the system that works for one that you're trying to develop?They're making it vision-only and powered by artificial intelligence. It might work worse right now, but one day it will work much better than Toyota's ever will.
