Does the app support the Konnwei OBDIng bluetooth dongle? Thanks
I don't know for sure but it should. However, an OBDLink LX will be better.
The dongle support CAN bus, app says "read fail, socket might closed or timeout"
Thanks for your help. Looks like mobile isn't connecting to bluetooth dongle, had it paired to mobile about 6 months ago, but won't connected now !?.. have unpaired, and trying to repair but device can't be seen !. So isn't the app, so appoloigies.
I have had several issues related to OBDLink LX where the bluetooth connectivity stops working, the only way i was able to get it working is to disconnect and reconnect the adapter.
Are you sure it is not the cable? I have the LX and not had any drops - not much use but just saying - normally things I buy don't work as intended!
James
What sort of time period? I can check mine if I know what time we are talking about.I have the same issue with the OBDLink to responding after a while, unplug and plugging back in sorts it out
Just connect to the OBD port under steering wheel just so that you can connect to device and update firmwareI installed the OBDLink app. It wouldn't connect with the device attached to the Tesla - had to move it to an ICE relic. It would then connect, so I started the firmware update process (from 4.3 to 4.5.1). The update process aborted with an error part-way through and now my OBDLink is bricked.
The lights still come on and it can be paired with, but no app can connect to it.
Sigh.
I recently went through this.I installed the OBDLink app. It wouldn't connect with the device attached to the Tesla - had to move it to an ICE relic. It would then connect, so I started the firmware update process (from 4.3 to 4.5.1). The update process aborted with an error part-way through and now my OBDLink is bricked.
Sigh.
Go to settings - Firmware update - little menu on the upper right - firmware restore
In that menu you can choose between many recent firmware versions for the OBDLink adapter, just get the latest one.
This may or may not work and related to other apps I use.@amund7 any way to prevent the app from going to sleep/disconnecting from Bluetooth during a recording session while it's running in the background?
It doesn't go to sleep if active on top but disconnects if it's running in the background.
