What do you mean?
I should let it sit, plugged, at 100% until all the cells have the same voltage?
Your pack is only as strong as the weakest brick of cells. But you could drain it some and then charge it to 100% again. And the slower you charge it the less difference you should have between the lowest and highest brick voltage. (So you could set it to charge at 6A if you wanted.)
But it really isn't going to make much of a difference.
Also, while it says the lowest cell is 4.178, the details don't actually show any cell that low.
