Zilla91
May as well, if more people report then it might push the fix up the priority listMine's gone awol since .6 yesterday is it worth reporting it ? presumably if its sw then it wont fix till next update?
Or the update after that or the one after that.Mine's gone awol since .6 yesterday is it worth reporting it ? presumably if its sw then it wont fix till next update?
inevitably its now working again when i went out to take a pic for the report....May as well, if more people report then it might push the fix up the priority list
I had something similar I was just using ACC / EAP and it started saying unavailable then I noticed there was nothing on the right of the screen - I was just trying to set my cruise control so didn’t notice then screen went white and reloaded and it started working again?If you go into the car menu and hit the notification icon at the top there should be a log item displayed saying it’s crashed
Reporting it could help Tesla collect data on the bug.Mine's gone awol since .6 yesterday is it worth reporting it ? presumably if its sw then it wont fix till next update?
I got this update yesterday.Meanwhile, 2024.2.7 is starting to roll out, and maybe it fixes this bug.
I can’t auto lane change anyway, it just seems odd it tells you it can’t tell you when you’re drifting out of lane, but seems to think it can keep you in laneThe LDW prevent you from auto-lane change most times.
Autopilot does work with LDW. If you have auto-lane change, that fails much of the time when the warning is displayed. And because the LDW warnings can pop up every few seconds when driving on the motorway it’s a 50-50 gamble if your lane change will work or not. The frustration it causes is immense.Are others able to use AP even when getting LDW? I’d understand if you didn’t want to try, I only did for a shortish bit of quiet dual carriageway but it worked
I get the feeling they could fix the LDW issue if they were bothered to try
For the same reason it says "contents may be hot" on a cup of coffee. Idiots + LawyersSeriously how the hell can they build a car where on almost every drive the vehicle throws up warnings or moans about something or another. There should be no warnings 99% of the time.
The cameras should not moan if it’s sunny, dark, cold or rainy. It’s pathetic.
