Morristhecat
Ok, was able to upload my sticker now. Interesting that we all have different variations. @slcuervo, notice that your combined weight capacity is 100lb less than mine. That could be the reason for the lower psi perhpas?
How strange!Morristhecat, you have an Model S 60, which I think is lighter than the 85, so this could explain why your allowed combined weight is higher, and thus have higher PSI recommended?
I still can't believe the traction control engages so much. I don't find it normal, and I would like you guys to share your thoughts, but more importantly your experience, so we can compare. I might even open a new thread to discuss this particular issue.
If I accelerate briskly from a wet intersection, I may get some slip as the drive wheels cross the painted surface where the crosswalk is marked (slips on the shiny paint surface), but my summers will do that too.
I'm getting my R2s put on this afternoon.
When you describe the situation above, is that with the summer tires?Anyway, let me know what you find out once you have the R2s on!
Yes, you need a wheel alignment.
Is it typical in Saskatchewan to install winter tires so "early"? Here in Southern Ontario, I usually wait until mid-November.
Pics or it didn't... oh, well... you know.
Should I wait until Spring to get the alignment (when my summer wheels are back on) or is the wheel/tire combo irrelevant in this case?
Did the Nokian behaviour disappear after sometime? Mine are still new and they cause the traction control light to appear every time I accelerate.
R2s have been out-of-stock, so just got a set of Xi3s. Hopefully they work out well.
A heads up: Apparently all the new Tesla's out there, and maybe this thread, are driving up the demand for the Hakka R2 in the 245/45R19 size. I could not find them locally in Colorado. I called TiresByWeb, they told me that national stock had been sold out, but a new shipment just arrived from Finland in that size and they currently do have some. My four R2's for my new P85D are on the way. :biggrin:
I had the same problem in Denver. The Tire Rack distribution Center in Stapleton has the Xi3 in stock for same day pickup.
