zoomer0056
How could that help?. If the siren is heard but the ambulance is never seen, was there really an emergency?If adding microphones helps AVs detect emergency vehicles sooner
Agree. But I'm sure Elon thinks he can listen with Vision.If adding microphones helps AVs detect emergency vehicles sooner, that would be a good thing.
Cross traffic emergency vehicle in a city. You have the green, but hear it approaching so you don't enter the intersection.How could that help?. If the siren is heard but the ambulance is never seen, was there really an emergency?
Yes, this I can see. I can also envision a bunch of cars frozen and blocking the way because the emergency vehicle can't be seen. Not a trivial problem.Cross traffic emergency vehicle in a city. You have the green, but hear it approaching so you don't enter the intersection.
Here are some examples:Yes, this I can see. I can also envision a bunch of cars frozen and blocking the way because the emergency vehicle can't be seen. Not a trivial problem.
Nah, there are things worse than having no data input...The worst sensor is no sensor.
Yup, those examples are easy to react to with visual input. I wonder if those vehicles use sound input at diplomat suggests would be good.Here are some examples:
Yeah poor examples, sorry. I have seen one where is definately uses sound to wait in an intersection.Yup, those examples are easy to react to with visual input. I wonder if those vehicles use sound input at diplomat suggests would be good.
Uh... If the car is moving, every object in the images moves from frame to frame, except for those moving directly toward or away from ego, which instead only bloom or shrink.Sure there is, It would work something like this:
1. Look at a frame from the cameras. Tentatively identify cars and other objects that might be moving.
2, Check for positional changes in subsequent frames. Spawn a new thread to track each object that is determined to be in motion.
3. In each "moving object" thread, conintiually update the position and predicted path of the tracked object. Extrapolate to predict possible intersections with ego and/or ego's predicted path.
4. Terminate threads whose objects have stopped moving or cannot intersect ego's path.
5. Rinse and repeat.
You get the idea. Predicting the positions of dozens of vehicles with C code is trivial compared to, say, predicting the position of millions of particles in fluid dynamics simulations. That's not to say that NNs aren't a better solution, but procedural and object oriented programming has handled problems more complex than this for many decades.
.....and how is this accomplished?....Many EU countries have sirens that make it very easy to locate the source.
Sirens are a work around to the limitation that human drivers can only look in one place at a time and they get distracted. I'm not sure what useful action an AV would take in response to the sound of a siren.No one should be responding to sirens alone, visual cues are more important for avoiding emergency vehicles, other cars pulling over around you, etc.
I doubt anyone gets pulled over for making some effort to not block emergency vehicles
The more difficult task to know when to avoid an emergency scene vs drive through it
Not enter an intersection? I was first at a stoplight and heard a siten but could not immediately see where it was coming from. Light turned green but nobody moved. 15 seconds later the fire truck crossed in front of me. If I had moved I would have impeded its progress.I'm not sure what useful action an AV would take in response to the sound of a siren.
sometimes driving in big cities is definitely both!Not sure if this is impressive or terrifying or both?
You can hear a siren before you can see the vehicle.Sirens are a work around to the limitation that human drivers can only look in one place at a time and they get distracted. I'm not sure what useful action an AV would take in response to the sound of a siren.
I think there's a disconnect in the discussion - are looking at what's required or what's 'best?' Required is pretty clear cut; Best is open to interpretation.I always find these types of arguments a bit silly. Just because we allow something does not mean it is the best approach. I would argue that non deaf people probably handle emergency vehicles more reliably than deaf people because they can hear the sirens. And we want AVs to be as reliable as possible. If adding microphones helps AVs detect emergency vehicles sooner, that would be a good thing.
That's not quite true. First, I am still not convinced v12 is one, single end-to-end NN. It is most likely a cascade of NNs. So the driving decision NN takes a variety of inputs beyond the output from the occupancy network (built from the cameras). This includes inputs from speed sensors, accelerometers, mapping data, navigation data, and the like. It also includes user settings, such as speed-offset, the selected FSD driving "profile," "Exit Passing Lane, "Require Lane Change Confirmation," and the like. Are you suggesting that each of these settings requires a different FSD stack? Just make the autonomous mode (Autopilot vs. NoA/Autosteer on City Streets) an additional setting. One stack to rule them all.Not sure what you mean. The end-to-end stack takes input from the cameras. It does not take input from the autonomous mode. And the end-to-end stack is trained on video to perform certain tasks like handle a roundabout, a lane change, an unprotected turn, a 4 way stop etc... So I am not sure how you would input to tell the end-to-end that you just want AP mode or FSD mode if that is what you are suggesting.
