I called the Decatur SC...they told me to buy a new car if I wanted the new MCU After I mentioned the Tweet...They informed me they will look into it and provide me an update.Aaaannnnd... cue every service center getting their phones rang off the hook and inboxes full....
Got an email back from the Shop Supervisor...I called the Decatur SC...they told me to buy a new car if I wanted the new MCU After I mentioned the Tweet...They informed me they will look into it and provide me an update.
Hey does anyone know how to crash your old MCU so it looks like a warranty issue?
#AskingForAFriend
Probably means confirmed but timing is always an issue.I'm not sure if an Elon tweet means [confirmed]
I'm still waiting for a lot of tweets to come to fruition.
Am I the only one not thrilled if a successor to a 7 year old system only has double the speed? Should be much, much faster, no?Check this video comparing Old VS New MCU :
Most likely is, but limited by software. Even the newest state of the art touch hardware can feel slow if the software has not followed in time.Am I the only one not thrilled if a successor to a 7 year old system only has double the speed? Should be much, much faster, no?
and...Not confirmed until it's been done atleast once. But I'm glad we're getting an answer other than "No".
Umm, no it doesn't at least not on MCU1. The IC displays things from the can bus, and yes some bits from the MCU, but the IC isn't just a dumb display terminal for the MCU1, now it is or appears to be a simply a display terminal for MCU2 and probably not even on the network or can bus, but until someone visits me or someone else with an MCU2 car, we can only speculate for now, but it's pretty good speculation at this point given all we know and the behaviors we've seen.
I would be happy even if the IC display isn’t upgraded, that would make the replacement a lot simpler but would require some custom code on the retrofit to output data to the old IC display. The old IC display is just fine, it is the main screen that is so slow.
Elon has an amazing knowledge of the engineering details, so I'm sure he knows the swap is trivial.
Non-trivial changes are usually not suggested by Elon. Such as AP1->AP2 (explicitly stated) or AP2>AP2 5 (never mentioned).Who said it was trivial?
