yes.. that's true..
although Spotify was in the code long before it made its way iirc.. even to European cars and forever for NA cars.
Perhaps @omarsultan could post his sources list, if he got the chance?
yes.. that's true..
It may end up being the case, but I wouldn't necessarily be sad about it, as the S definitely seems to be a much nicer car overall.If your estimate accurate, that would be quite disappointing. That would mean that for regular everyday driving without prep, the LR that I just spent $100k on with 21” wheels and FSD, would be slower than my Performance Model Y.
I hope this isn’t the case!
Contact your SA. Highly doubtful that changing your trim will incur a price penalty, it’s not a new order.I am so frustrated. Ordered my MS Plaid 6 months ago. Wood trim was not an option, and now people who ordered just recently are going to be receiving delivery because they chose wood trim. I would swap out for wood trim in a second if it meant delivery, nobody is offering that option. If i make a new car order, it is another $10k. Thats just not right.
You need to update your signatureCongrats!
Canceled LR order, VIN is for Plaid.
Any change normally results in re-pricing. Changing color, wheels, interior, etc.Contact your SA. Highly doubtful that changing your trim will incur a price penalty, it’s not a new order.
The benefit of the wall connector is that you can charge at 48 amps vs 32 amps for the mobile connector. It just depends on your use scenario. If you drive a lot in the day and need to quickly top off to do something in the evening then it is worth the added cost for the faster charging. If you will only be charging at night, then it doesn’t really matter.What do you guys recommend for home charging - nema or wall connector?
I went with Wall Connector. Kind of a waste of money for a few extra M/H charge rate, but I want to just leave the mobile cables in the car and not touch them unless I need them on a trip. I figured we are also talking a $500 price difference on a six-figure car. I‘m all for pinching pennies, but this didn’t seem worth it to me.What do you guys recommend for home charging - nema or wall connector?
100% True. It's why I switched back to Model S. The Y was a bit disappointing. Just felt different. And I missed my pop-out door handles. I know that's a trivial thing, but also quite wonderful in Arizona heat.It may end up being the case, but I wouldn't necessarily be sad about it, as the S definitely seems to be a much nicer car overall.![]()
Glad you agree. Also, great choice with the Roadster. Elon was tweeting today that Tesla may have a few tricks up its sleeves to further increase torque and maximum rpm for the Roadster's motors.100% True. It's why I switched back to Model S. The Y was a bit disappointing. Just felt different. And I missed my pop-out door handles. I know that's a trivial thing, but also quite wonderful in Arizona heat.
I'm excited for the upgraded interior and would've even considered moving to plaid at the old price if it would have had 400+ mile range. At this point I'll just stick with LR andpatientlywait as thedaysmonths click by. I'll keep the $50k and put it toward an eventual roadster.
Now, Tesla and my Monroney sticker both state a range of 348. But 170 miles / 0.44 = 386 miles and 310 miles / 0.79 = 392 miles, which implies either the rated miles algorithm is off or Tesla is sand-bagging.
- Started: 44% / 170 miles
- Ended: 79% / 310 miles
- kWh added during charging session (per Tessie): 35.2 kWh
That will be nice to see. Should provide some confirmatory data.I am planning on hitting a 250 kWh charger in the next couple of days and recording the whole session.
it could be that charging rate is going to be artificially low until they decide they're ready to juice it.
If your estimate is accurate, that would be quite disappointing. That would mean that for regular everyday driving without prep, the LR that I just spent $100k on with 21” wheels and FSD, would be slower than my Performance Model Y.
It's possible, but the S is still a much, much nicer car.Cannor see that happening.
@AlanSubie4Life - You are killing me with the amount of data in that post! Am I the only one that feels like my head is about to explode?Sorry, this is going to be long and a bit detailed.
This is not unusual. It APPEARS they just have not adjusted the mileage to be correct for your car (wrong constant). It looks like you just have the 390@100% display (should be visible on the slider in the app if you do that, assuming it works that way for Plaid) - this is appropriate for the 19" version. Would be great to confirm this though. This happens ALL the time with Tesla at the beginning of a new model introduction. If you have 21" wheels (from your Monroney), you should expect a range (constant) adjustment at some point. But they may also unlock capacity or make efficiency changes so who knows what your final rated miles at 100% will be after things settle out (it could easily be more than 348 miles, since that is not an official EPA result yet).
From Tessie and your data, your constant is like all others captured, at 35.2kWh/143rmi = 246 Wh/rmi. (The 143mi is not from your original post, it is from your follow-up graphs, which are more accurate.) If you capture a picture while supercharging, you'll get the same constant of 246Wh/rmi, as described earlier (kW / mi/hr) - notwithstanding intervening software updates, which could change the display constant.
So the calculation I referred to (which has always worked, to my knowledge before) gives: 390rmi*246Wh/rmi = 96kWh (this is including the buffer; the way the calculation works). This gives the value of the degradation threshold, or the nominal full pack, whichever is less. In this case I definitely think it is the degradation threshold!
My current understanding is that the “kWh added” values displayed by the car during a charge session are not correct (for any Tesla). When the car nominal full pack capacity is below the degradation threshold, they’re always off from the actual kWh added to the battery by the buffer %. (This can be readily confirmed via readbacks from SMT; for example for Model 3 below the degradation threshold (showing rated mile loss), you'll find the SMT delta in nominal remaining will be 4.5% less than the car says is added during the session. You can also (probably) confirm it by carefully integrating the kW from the supercharger over time and compare to what it says the kWh added is - but that's harder since you have to do integration, lol.)
Anyway, these kWh added values are simply a calculation from rated miles added * charging constant. That's what they're always equal to. It's not a kWh meter measuring actual energy added to the pack. (You really need SMT or similar to access that value easily.)
Ok, so what is (slightly) surprising to me:
1) The 96kWh degradation threshold (not your full pack capacity in this case, nearly certainly, since the car is new) is considerably lower than what the Monroney sticker implies (103kWh as previously discussed).
In and of itself, it's not unusual for this calculation to come up with a slightly lower value than the actual pack capacity for a new car - but normally it is just by a 1-2kWh at most - not 7kWh (for example 2021 Model 3 Performance has packs at about 81.5kWh with a threshold of 80.6kWh). In any case, Tesla can pick the constant however they want - but to the extent it results in a degradation threshold much lower than the actual nominal full pack, it just indicates that the rated miles will contain more ACTUAL energy than that constant actually indicates, until the ACTUAL capacity of the pack drops below that threshold. (This fact has been verified on the 2021 Model 3 Performance recently, and it's long been speculated.)
Going back to the above discussion about "added kWh", this means that each rated mile (not to be confused with the displayed rated miles; the displayed miles are lower energy content by the buffer %) on your vehicle right now may well contain more than 246Wh. So that 35.2kWh above may well have been more like 103kWh/390rmi * 143rmi * buffer adjustment (say 0.97) = 36.6kWh truly added to the vehicle (what you would see in SMT as the delta if it were connected).
2) The constant is very low right now (246Wh/rmi). For perspective, the constant on the new 2021 Model 3 Performance is 255Wh/rmi. So I do not believe that 246Wh/rmi is a reasonable value for Plaid in spite of all of the improvements (it has a larger frontal area and drag, and it's a heavier vehicle - though it will be very efficient I think). I expect a value (for the 390-mile vehicle) to be closer to 103kWh/390mi = 264Wh/rmi (and similarly 296Wh/rmi for the 21" version with 348 rated miles - though this may end up a bit lower if the EPA test does better than 348 miles which it might). These values are pretty excellent for such a large vehicle, though!
Here's what you could do to help continue to answer this question:
The ACTUAL energy content per displayed rated mile can be measured:
1) Switch to Energy Display -> Distance Mode (Not Energy - so miles shows in the instrument cluster, not %).
2) Take a decent length trip (using over 100 rated miles would be great, but even 30-50 miles would be ok in this case), without stopping. Log the rated miles at the beginning of the trip, before starting moving, exactly. (Picture #1)
3) At the end of the trip, IMMEDIATELY after putting the car in park, log the rated miles. (Picture #2) Simultaneously, again immediately after putting in park (forces update to the trip meter), log the trip meter "Since x:xx" details, exactly. If it's a shorter trip, try not to end the trip with too much regen (drive some surface streets and come to a stop on a slight uphill). (Picture #3)
You do the calculation: (Trip Distance * Trip Wh/mi) / (Rated Miles used)
I would expect for your vehicle, right now, for this calculation to come up with:
264Wh/rmi * 0.96 = 253Wh/rmi (approximately). (Again, with just 30-50 rated miles used for a shorter trip, we'll only have 2 sig figs, so we can only say it will be between 250 and 260Wh/rmi (which would still be helpful to dial in on the actual pack capacity). )
However, I could be wrong, and this value is a) completely dependent on the Monroney sticker values being correct and predicting about 103kWh of capacity, and b) it assumes a 3% buffer, and c) it assumes 1% heat losses.
So, if anyone has a chance with a Plaid to do this procedure, it would help shed light on this. It's super easy to do if you happen to be driving around. Just have to be sure to carefully log the starting and ending rated miles and you can't do any stops (since you lose energy while parked). This is essentially equivalent to driving a really long way and comparing % use to kWh use on the trip meter - but using miles is more accurate and this allows a shorter trip.
Your data so far has shown that the degradation threshold as currently set is 96kWh. But the pack capacity is likely higher than that, and to dial in on that value without SMT, the only option is to do this metering test. In the end this metering will only give us the energy available above 0%, and for now we'll have to make educated guesses about the buffer size (3% seems reasonable).
Summary:
I realize some of the above is confusing and counter-intuitive, and it requires familiarity with how the Tesla displays operate to follow. Tesla's energy display stuff is a little weird, but so far it is very consistent! It's just my current understanding, though, so I'm open to corrections or thoughts.
1) Evidence points toward unlocked nominal pack capacity right now of ~103kWh on Plaid. However that is based ENTIRELY on the Monroney, which is not final. Everything hinges on this. Really the only firm data we have and it is preliminary.
2) Degradation threshold is (currently) around 96kWh. This is the nominal full pack capacity where range loss will start to show (a long way off).
3) Even the 21" vehicles seem to be displaying 390 miles of range (contradicts Monroney)
4) For a new vehicle, I expect each displayed rated mile to contain 256Wh, which will show as 253Wh on the trip meter. That would imply 99.8kWh available above 0%. (And I'm assuming a 3% buffer which would take things to 103kWh total.)
5) Overall confidence level here on all claims is quite low.
6) I expect updates from Tesla in future to adjust ranges (constants) of vehicles appropriately, and they may be accompanied by changes to range from 348/390 miles, and also (small) changes in the unlocked available capacity. I also expect a change (increase) to the degradation threshold (this does not adjust the buffer size, but it's the only way for Tesla to make the rated miles AND the constant simultaneously to be more representative of EPA results). In the end I expect the threshold to be just a couple kWh below the "full pack when new" value. Might be months though before this happens.
I’m not looking at these numbers for the charge rate - just the constant. But there is really no guarantee the constant is correct right now for this display calculation (it eventually will be). To me it looks like it is adjusted for a 420-mile car (103.3kWh/246Wh/rmi = 420 miles), but I could be wrong.
I kind of think this 246Wh/mi and 103kWh capacity is kind of an Easter egg to work out to 420 miles, but the display not actually showing 420 miles at 100% (because the degradation threshold is set to 96kWh rather than 103.3kWh) makes it kind of a lackluster Easter egg.
I guess we'll see.
I think I need to take a breather and circle back to that post.
They don't care about lying. They've repeatedly lied about the delivery dates for the refresh. You'd have to be really gullible at this point to think the lies are just good-faith errors caused by parts shortages and battery fires. Elon said this car was in production in January. Does anybody really believe that now?+ converted to Plaid at older pricing. Base car with red as the only option. Still an RN.
How many out there are + to Plaid?
Where did you end up pricing wise?
Any + to Plaids getting a VIN?
The call I got (which I was reminded each and every time was being recorded) came with the pitch "trade your + order for a Plaid June delivery". That seems somewhat suicidal on Tesla's part given we are making promises with a three week window. It is pretty obvious that you knew, or should have known, that this was a disingenuous pitch if you end up missing the June delivery. I'm not saying Tesla is not going to do what they said they would do; I'm only saying they constructed a very tight box to climb into.
Haha. There's actually very little data (that's the problem, haha!). But it's very dense, lots of words, lol. I blame Tesla for their rather arcane display of rated miles and other data. As I said, at least their treatment (so far) has been consistent.@AlanSubie4Life - You are killing me with the amount of data in that post! Am I the only one that feels like my head is about to explode?
I think I need to take a breather and circle back to that post. Do these calculations tell us when our cars might be arriving?![]()
Sorry I didn’t read your thesis but it seems like you know what you’re talking about and I’m sure you’re correct.Sorry, this is going to be long and a bit detailed.
In and of itself, it's not unusual for this calculation to come up with a slightly lower value than the actual "design" pack capacity for a new car - but normally it is just by a 1-2kWh at most - not 7kWh (for example 2021 Model 3 Performance has a pack at about 81.5kWh, with a threshold of 80.6kWh). In any case, Tesla can pick the constant however they want - but to the extent it results in a degradation threshold much lower than the actual nominal full pack, it just indicates that the rated miles will contain more ACTUAL energy than that constant actually indicates, until the ACTUAL capacity of the pack drops below that threshold. (This fact has been verified on the 2021 Model 3 Performance recently, and it's long been speculated.)
Going back to the above discussion about "added kWh", this means that each rated mile (not to be confused with the displayed rated miles; the displayed miles are lower energy content than the "charging" rated miles, by the buffer %) on your vehicle right now may well contain more than the 246Wh implied by the constant. So that 35.2kWh shown on the instrument panel above may well have been more like 103kWh/390rmi * 143rmi * buffer adjustment (say 0.97) = 36.6kWh truly added to the vehicle (what you would see in SMT as the delta, if it were connected).
2) The constant is very low right now (246Wh/rmi). For perspective, the constant on the new 2021 Model 3 Performance (with heat pump!) is 255Wh/rmi. So I do not believe that 246Wh/rmi is a reasonable value for Plaid in spite of all of the improvements (it has a larger frontal area and probably higher drag in spite of its lower Cd, and it's a heavier vehicle - though it will be very efficient I think). I expect a value (for the 390-mile vehicle) to be closer to 103kWh/390mi = 264Wh/rmi (and similarly 296Wh/rmi for the 21" version with 348 rated miles - though this may end up a bit lower if the EPA test does better than 348 miles, which it very well might). These values are pretty excellent for such a large vehicle, though!
Anyway these constants are kind of arbitrary in the end, and they really don't matter for pack capacity, or anything, really - constant goes up, range goes down, and vice versa, for a given pack size. They're just a unit of measurement.
Here's what you could do to help continue to answer this question about actual pack capacity:
1) Switch to Energy Display -> Distance Mode (Not Energy - so miles (or preferably km actually - 1.6x better - can switch back to miles for the actual drive) shows in the instrument cluster, not %).
2) Take a decent length trip (using over 100 rated miles would be great, but even 30-50 miles (or 100rkm!) would be ok in this case), without stopping. Log the rated miles at the beginning of the trip, before starting moving, exactly. (Picture #1)
You post pictures and do the calculation: (Trip Distance * Trip Wh/mi) / (Rated Miles used)
So, if anyone has a chance with a Plaid to do this procedure, it would help shed light on this. It's super easy to do if you happen to be driving around. Just have to be sure to carefully log the starting and ending rated miles and you can't do any stops (since you lose energy while parked). This is essentially equivalent to driving a really long way and comparing % use to kWh use on the trip meter as people often do - but using miles (or preferably km) rather than % is more accurate, and this allows a shorter trip.
Summary:
I realize some of the above is confusing and counter-intuitive, and it requires familiarity with how the Tesla energy displays operate to follow along, probably. Tesla's energy display stuff is a little weird, but so far it is very consistent! It's just my current understanding, though, so I'm open to corrections or thoughts.
1) Evidence points toward unlocked nominal pack capacity right now of ~103kWh on Plaid. However that is based ENTIRELY on the posted Monroney, which is not final. Everything I am assuming hinges on this. Really the only firm data we have and it is preliminary.
6) I expect updates from Tesla in future to adjust ranges (constants) of vehicles appropriately, and they may be accompanied by changes to range from 348/390 miles, and also (small) changes in the unlocked available capacity. I also expect a change (increase) to the degradation threshold (this does not adjust the buffer size, but it's the only way for Tesla to make the rated miles AND the constant simultaneously be more representative of EPA results). In the end I expect the threshold to be just a couple kWh below the "full pack when new" value. Might be months though before this happens.
I kind of think this 246Wh/mi and 103kWh capacity is kind of an Easter egg to work out to 420 miles, but the display not actually showing 420 miles at 100% (because the degradation threshold is set to 96kWh rather than 103.3kWh as would be required) makes it kind of a lackluster Easter egg.
I guess we'll see.
Well you ordered in June and lots of others have ordered way further ahead of you. Most of us can't get even an estimate.Talk about crushed dreams lol
Haha. Lots of words do not make it correct, for sure! I have looked at this a lot for Model 3 and I have a LOT more confidence in that domain right now. As I said for Model S Plaid my overall confidence level is low right now, due to lack of data, and lack of familiarity with how they may alter treatment of the BMS & display for this line of vehicles.Sorry I didn’t read your thesis but it seems like you know what you’re taking about and I’m sure you’re correct.![]()
