Hi all,
Got a few questions that am hoping will be quick fire ones for those in the know...
1. If IO give you a charge window out of the 6 hours overnight do you also get the 7p rate for other electric usage other than the x kW identified that is needed for charging the car? So if they gave me a slot of 10 to 11pm, would it be 7p per kW for all electric used in that window or do they use the app to work our how much is at the cheaper rate?
2. Has anyone used a battery to simply charge from the grid at night rather than solar panels? My house will be a pain to install solar because of shade etc, so wonder whether a couple of decent batteries that fill up between 23.30 and 05.30. Then use that to run from for the following day. Essentially resulting in a 24/7 7p tariff.
Any advice would be much appreciated. And thanks for all the great advice found through this forum already.
