Aesthetics are a matter of taste and opinion, it is hard to argue with anyone's personal taste.
Doug left out fuel cost which more than closes any gap in price compared to base diesel trucks IMO.
Even if we call it a wash on price the other advantages of Cybertruck are:-
I think range while towing is an open question, and is the only area that may disappoint Cybertruck fans,
- Low maintenance
- Bigger cabin (than most)
- Acceleration and handling
- Ride comfort
- Off-road ability
- Lockable storage (multiple options)
If you are going to tow big loads long distances plan on get then $70,000 model and hope to be pleasantly surprised..
Even if that 500 miles of range comes down to something like 350, that is still workable for nearly all trips.
This is the load you can pull with a tow strap. Meaning there is no weight supported by the truck and there is no pushing (braking of the towed object) by the truck.Can anyone explain the meaning of “Pulls ∞” in this slide?
Also an open question how you park at the supercharger stall while towing a trailer...
...something that I've seen pointed out: the tug of war wasn't equal. The F-150 was spinning the rear wheels only, and didn't have 4x4 badging.
None of these guys are going to give Tesla the benefit of the doubt on the Cybertruck. Tesla is going to have to prove it out every step of the way for the next three years.This is a million mile vehicle potentially (still unconfirmed) and comparing it to any 200k mile vehicle on some sort of value basis is missing a lot. Really, comparing it to any vehicle other than maybe a train car is inappropriate. The body should be nearly indestructible and the drive unit and battery are pushing toward delivering a million miles.
Sales tax kills it - unless the FSD costs like 15k.Am I reading this wrong? If FSD, at the time of the truck deliveries, is say 25% higher, then that $100 option becomes a huge gain as one could buy the truck and turn around and sell it at a profit.
Well if FSD is 100% done by then then I would think it could cost 15k or much more. Let's say more likely deliveries start in 2022.Sales tax kills it - unless the FSD costs like 15k.
It means you can apply a consistent pulling force even at zero speed for an extended time to get the load rolling.
Usually at a crossing.If you have a constant pulling force and are at zero speed for an extended time, you'll probably be at zero speed forever.
If you get any non zero speed, then you'll accelerate the load up untill losses equal force.
Then there is the use of momentum and the tow line compliance. If you can build speed before the line is fully stretched, then that impulse can break static friction. Trains somestines reverse to put slack between all the cars before accelerating.
I am wondering if this is going to be the surprise. And this is all pie in the sky thoughts but.....If you are going to tow big loads long distances plan on get then $70,000 model and hope to be pleasantly surprised..
Tri motor ordered just now.
RN1130126**
So where's the order estimate today?
So 250+ mile on a towing and loaded truck with the new 120kW battery.
300+ miles on a towing and loaded truck with the new 200kW battery
500+ miles on a towing and loaded truck with one 120kW and one 200kW batteries together.
(One battery may run the front motor and the other the back two)
Racy thoughts but I bet that would do it...... but cost....
It would be convenient to have access to climate services (heat/AC) if sleeping in the bed and it would be interesting to have crawl-through access as well but I can't quite fathom how that would be possible with the mechanical cover mechanism.
Am I missing something?
Only that the cover completely retracts and rolls up under the cab. So if you are using the pass-through you can't open/close the vault cover. (And maybe you couldn't use it at all if the vault cover is closed.)
The interior bed shot on Tesla's web page doesn't show any sign of an opening.Teslarati is reporting that there is a pass-through from the cab to the bed.
Top 10 Tesla Cybertruck hidden features you may have missed
This does not seem correct to me. I think it is more likely access to a storage area behind the rear seats or access to the bed cover mechanism (for service).
I can't quite imagine how the mechanical cover for the bed would allow a pass-through. That would require the cover roll to be above the pass-through portal. It does not work out as I see it.
