Has any consideration been given for the temperature differential to the squirrel cage style rotor? I believe the rotor is all metal, so it can take extra heat, however you will lose some performance once you pass 100 Celsius due to I2R effects. I suspect these features will be most pronounced during extended freeway drives. I can get mine running I will work on data for performance versus temp effects on the rotor
google "induction motor broken rotor bar" and "induction motor laminate failure" Lots of studies illustrate temperature effect on rotor thermal stress. Rotor is the most interior and naturally the hottest and hardest part of an induction motor (IM) to cool.
I do read service life of (IM) goes down drastically with temperature increase (some say 10x shorter service life with just 50C increase). Furthermore, highest current flow is starting the motor thus industrial AC IM applications advise to keep it running all the time. Usage in a car is constant start/stop/regen condition if not highway. The power meter on the instrument panel provide a pretty clear visualization how much current is going through the IM rotor. Even gentlest acceleration and regen hits like 50-60kW while highway cruising is like < 20kW. So just normal start stop driving is likely the most thermally stressful condition.
It could very well be a 20+ year life cycle got reduced to even 2-4 years by coolant delete which is still far better than Tesla's reman LDU leakage failure rate.
It'd be wise to start researching robust cooled rotor solutions as well as rotor sourcing if they do start failing in a couple of years time. I've been in touch with leading edge coolant seal + water pump design companies to get them interested. Difficult to create momentum without rotor failure appearing. If rotor failures appear, sourcing that will be very challenging and expensive.
