brainhouston
i believe that depends on the state of the car/components... and some white # don't have temps.
when car is off, DU will just have dashes
i think charger only shows temp when its charging...
Not to confuse, but there is another source of accel-only noise, that is not a bearing: it's "Contactor Squeal", on the early vehicles. See Tesla Note TN-13-16-002 R1. I had this for a few months, after the HV battery was replaced under warranty. It went away. It was variable "pitch" for me, and would change as I pressed or released the accel pedal.I’m starting to hear the high pitched sound when putting light pressure on the “gas” pedal. The noise is not there during coasting or generative driving. It sounds more electric that bearings, kind of like a mig welder. According to a former Tesla technician, it definitely are the bearings. Am I correct to assume that coolant has entered and is now causing the bearings to start going bad? Or are these two different issues? I assume a coolant delete will not help in my case as I’m guessing the bearing noise will only get worse over time.
I'm going to do the delete for sure when the supply of caps come in and replace the rotor bearings at the very minimum. A tip I picked up somewhere - when you pull your speed sensor, don't use the blue shop paper towels to wipe it. Instead, use a white paper towel from the kitchen. This will allow you to see if whatever is on it is blue (coolant).@mr_hyde also has "not too many drops on speed sensor on 6+mo 10k miles ago pull" but hearing high pitch whines on acceleration now (mig welder sound is a good description). He has original factory LDU from 2014. I can hear the high pitch from 2 houses away when he comes by. We'll probably pull the speed sensor and do the coolant delete if present. Curious which bearing is sounding so bad.
My comment about the 'cool' coolant is specific to the coolant going into the top of the gearbox. In the original design, it is presumably very hot since it went through the rotor tube first. In the delete design, the coolant going to the top of the gearbox will be at the system's operating temperature. The 'cool' coolant will still mix with the hot coolant from the stator and inverter before exiting the LDU and the gearbox fluid sloshing around on the gear side of the heat exchanger is constantly mixed but the aggregate temperature of the gearbox and the coolant exiting the LDU will be cooler after the delete than it was before.not sure i fully understand this statement..
from my long trips experience, batteries heat up to 30-35C (range mode on, so just from DUs heat)
pretty sure Tesla does it for faster supercharging
I mentioned this to another owner a couple of weeks ago.A tip I picked up somewhere - when you pull your speed sensor, don't use the blue shop paper towels to wipe it. Instead, use a white paper towel from the kitchen. This will allow you to see if whatever is on it is blue (coolant).
Thanks for that: my car has always had that squeal if I accelerate hard. One single, high pitched tone which changed to a lower pitch. I had assumed it was the inverter, now I know.Not to confuse, but there is another source of accel-only noise, that is not a bearing: it's "Contactor Squeal", on the early vehicles. See Tesla Note TN-13-16-002 R1. I had this for a few months, after the HV battery was replaced under warranty. It went away. It was variable "pitch" for me, and would change as I pressed or released the accel pedal.
A leaking rotor coolant seal impacts the outer rotor bearing only, as the only place for the coolant to go is through the bearing, watering-down the lubricant on its way to the stator cavity. If your noise is truly a rotor bearing, it's likely to be just the one. But the coolant does damage further on, including lowering the stator winding's HV isolation resistance (covered extensively above in the last couple of pages), and eventually making its way to the power electronics on the inverter side of the LDU.
Bottom line: it almost certainly should have the rotor cover pulled for inspection, which is a subframe drop on a Model S.
this is interesting...
Greasy inverter case, not a really good sign.
Yeah it was definitely some of the greasy transparent jelly that made its way out, maybe they use it as a non conductive grease to make the housing slide easily over the big O ring and also against moisture intrusion but that's just guessingthis is interesting
when i looked at mine, it had same exact greasy spot, scared me a bit that it was coolant sipping out
i guess its a good sign for me![]()
So, wanted to post some extra data points since we also placed a rotor cap delete plug last night.
LDU HV cap. Moisture, but definitely no coolant just water (taste tested it) few hours later it was already evaporated so interesting.
Connectors looked like crap.
Then we decided to do iso test LDU, B+, B- and stator windings all where the same (4.7-4.8 Mohm)
So at this point no coolant under stator cap but moisture under HV cable cap.
So no moisture at all but a lot of sticky slime between the seal and housing? It looks like moisture on image but it is definitely not. Also some sticky slime on the bottom of the inverter housing. Unfortunately I don't have a picture of that.
So cleaned everything and placed the cap.
So you have to grind away the whole pipe, also the circlip that holds the insert in place because otherwise the cap won't fit. Hope it will stay in place![]()
Put everything back, added coolant and turned on coolant bleeding procedure.
Still not sure about the moisture on the HV cap and HV cables but think it's a good thing we pulled the inverter casing. We cleaned the HV cables and placed some very little grease on them (on top and above the O ring)
So.. just bought a salvage reman Rev q ldu to replace my utterly damaged non reman Rev q ldu. The reman one is clean , but I noticed this one
had a hole in the speed sensor area where the non reman Rev q does not. What's that all about?
