I just subscribed to FSD beta. I'm currently on 2022.44.25.3; I requested FSD beta, any idea how long it will take for the firmware to update?
I'm pretty sure Tesla has a simulated or actual HW4-equivalent system running with larger models.
I've had it over a year, 14k miles, tapping 5 times doesn't do anything nor does pressing and holding. I had subscribed back in sept before wide release and never got it. Now that it's wide release I was hoping it would update right away, but it just says there's no updates available. Looks like 44.25.5 or 44.30.5 is FSD beta, so I should be able to get the new update.Is your car new? Already drive 100 miles?
Did you try to go to software, and tap on advanced 5 times to check for update?
you are a bit harsh on Elon. Its not as if his words arent trustworthy.The Charlatan will just redefine FSD again to match the current city streets abomination that was released during the holiday’s.
I don’t care about intersections. I can take care of those details. It seems way too much to ask of the system to figure out how they work, reliably.I think most of all our annoyances stems from the intersections
If you wait for it after requesting and acknowledging the requirements, it will probably take between a couple of hours and a couple of days, assuming your car is connected to Wi-Fi. This seems typical based on comments here and the experience of myself and a friend.I've had it over a year, 14k miles, tapping 5 times doesn't do anything nor does pressing and holding. I had subscribed back in sept before wide release and never got it. Now that it's wide release I was hoping it would update right away, but it just says there's no updates available. Looks like 44.25.5 or 44.30.5 is FSD beta, so I should be able to get the new update.
I'm sure they had one for HW3 too.
Didn't stop them from being wrong about their guess on how much HW was needed for FSD to ever go beyond L2/city streets.
No reason to think having a HW4 simulation will either- unless you think that simulation is already safety-enough-for-public-release operating such a system.
Totally different story and time though. When they were developing HW3, the current stack wasn't even discovered / envisioned yet (transformers, occupancy network, autoregressive, etc.)
According to Karpathy, when he arrived (around time HW3 was first being designed), Tesla's NN team was training models on their desks.
The HW already is not redundant (and never really was in actual use).
As to how much "more" processing power they need.... nobody knows. Including Tesla.
Nobody WILL know until they get a working system.
Ok. Not sure how that changes anything.
At the time they thought they had a path forward, that HW3 would be enough for. They were wrong.
Then they changed paths (the big re-write) they ALSO thought HW3 would be enough for. They were wrong.
Nice to see some positive feedback for a change. You're right about creeping. It can be pretty scary thinking the car will launch you into traffic. After awhile if you're brave and wait, FSD will jerk to a stop. Just have you're foot over the brake. Tesla really needs to change this behavior so it creeps less aggressively like a human driver does.Tried FSDb on my 2023 Model 3 for the first time today and was very impressed. Was it perfect driving? Of course not. But it was far more impressive than any other ADAS available for purchase. Went 11 miles round trip and only disengaged once, because it was trying to make a right turn and creeping very close to cars going by at 55 mph, and I wasn’t comfortable enough with the system to let it do that yet.
Good to know - appreciate it!If you wait for it after requesting and acknowledging the requirements, it will probably take between a couple of hours and a couple of days, assuming your car is connected to Wi-Fi. This seems typical based on comments here and the experience of myself and a friend.
Some people suggest you can speed this up by actively checking for updates in the software menu. I never checked and it took about 24 hours for me, about 48 hours for my friend. It sounds like you've tried this already, so I'm saying don't worry too much unless it goes two or three days.
And, just going along these lines:A whole lot has changed since HW3 was being designed. We have a technique (bird's eye view, occupancy network), strategy (auto-labeling), a system that currently works doing very complex maneuvers, and a clear understanding of what's left to solve. I think people forget how far and magical Fsdb currently is (because we're mostly focused on all the frustrating issues or dangerous maneuvers).
We don't hear about fsd hardware failures, fsd going haywire, etc. And it's currently on hundreds of thousands of cars. This is very amazing...
If you consider all the things fsd can possibly do but doesn't (all its possible failure modes), it's mind boggling.
I think you disengage too often. I doubt you will get even 3/10 CULTS if you tried it. I guess his best was 8/10 ?For me: I believe FSD is nearly 9/10ths of the way there, and that is nowhere near good enough (results in 2-3 disengagements per mile with the way issues are currently distributed).
I’ll post another video at some point which does include another failed ULT. I have one I will post shortly but I have another. But yes very low success rate, all valid disengagements though. It’s just not very good at them especially without a center line marking. It’s particularly bad at dealing with left-turning traffic during a ULT (tries to cut them off through positioning (see first video) or by actually attempting to take right of way (future video)).I think you disengage too often. I doubt you will get even 3/10 CULTS if you tried it.
Disagree with only knowing after the fact. Important company projects minimize risks by spending the $$ up front to identify the issues, requirements, specifications, and then alpha-beta converge to a reliable solution versus wham-bamming something into always failing revisions/releases/promises for improvements. By using proper design cycles, a company always has the option of killing the project, saving face, and money.
The local cognoscenti on this forum have Made The Decision That The Hardware Isn't Capable Enough To Do The Job. (Which kind of fits with the glass-is-barely-damp mindset seen around here.)
Um. It's not like Tesla has said that. In fact, one has to dip straight into the what looks like conspiracy theories if internal Tesla people believe that the hardware's not capable.
First off, if they truly thought that HW3 couldn't do the job, why even bother writing software for a platform that can't keep up? Quit doing that and write software for a platform that can. Doing anything else is throwing $$ down the outhouse hole.
Unless.. The intent is to deny, defraud and so on. Right into Tesla-Q territory. There are certainly posters on this forum that think that way.
Shhhhh - stop talking like that. You'll anger the special people.And, just going along these lines:
The problem with that thinking is that it Only Takes One Whistleblower. NDA or not, one whistleblower to the world at large will corral the largest number of shareholder lawsuits the world has seen, action by the SEC, and so on. And it's just amazing what the discovery process will bring out in such a case.
Yeah, yeah: Everything that Elon says is aspirational, future performance isn't based upon past performance, and so on. But Tesla has been talking robotaxies and FSD for some time now like it's a thing that's coming. If they figure that they really can't do it, then some kind of damage control would have to kick in. Refunds. Promises of new hardware. There's been none of that.
And, as far as the Cybertruck and its purportedly more capable CPU: HW3 was designed in 2018 or thereabouts. This is 2023, five years later. Moore's law isn't dead, just slowed down. It would make financial sense to build a cheaper, faster CPU, using less silicon physical area, using more modern technologies. When one does silicon shrinkage, one can keep the same number of transistors and clock speed, the die will shrink, and they'll be much cheaper to produce. Or one can keep the die the same size, put down a heck of a lot more transistors at the same clock speed, and get more capability. Or, finally, do the thing that most CPU producers do: Shrink the die some, use more transistors, up the clock speed a bit, and get something more capable and cheaper than the old hardware. Geez, five years is like six dog lives in Internet Time.
The Cybertruck is coming out, what, late this year sometime? So it would make sense to stick the latest and greatest in that box, since, well, not worth the trouble to switch hardware right after a launch. Shortly after the Cybertruck hits the road, I'd imagine that the other Tesla products would start getting the new hardware. Again: Not necessarily because it's required, but more likely because it'll be cheaper.
