So I read this whole thread and I’m keeping up with it but I am still not sure I understand how the confirmation of lane change works in v9.... as those that have the 3 and the x/s might have noticed we need to turn off the blinker when using auto lane change, as opposed to the 3 that turns it off after lane change. Why is the v9 nav on autopilot different other than the car recommending the lane change vs me choosing (i understand the other differences such as blind spot and such but curious on the lane change part)?
Thank you to those that already have it and are sharing it with us
With the S/X, when the car requests a lane change with Navigate on Autopilot enabled (either to pass slow moving traffic or to get you to your exit), you can confirm that lane change with a single pull toward you on the auto-pilot stalk. This will turn on the turn signal and initiate the lane change, no need to use the blinker stalk.
You can use the blinker stalk at any time to initiate a lane change (even on multi-lane roads where Navigate on Autopilot is not supported); when you do this you must manually return the stalk to the center position when the lane change is complete. You can also of course use the blinker stalk to confirm a lane change request (but again, have to manually restore its position if you do so, unless you do a "half push")
