Which regulation? My Google search skills are failing me tonight!For some reason my car only updated (twice, once straight after the other) this afternoon. Ye Gods the new display is bad. My left hand now obscures the light icons and part of the speed display, which in my view is unacceptable. My understanding is that the speedometer has to be clearly visible at all times, and not be hidden behind the driver's left hand when driving with the hands correctly positioned on the steering wheel (the "ten to two" position).
I'll flag it to Tesla as a defect, as I suspect the car may now be non-compliant with UK regulations.
36.—(1) Every instrument for indicating speed fitted to a motor vehicle—
(a)in compliance with the requirements of regulation 35(1) or (3); or
(b)to which regulation 35(2)(h) relates and which is not, under the Community Recording Equipment Regulation, required to be equipped with the recording equipment mentioned in that paragraph,
shall be kept free from any obstruction which might prevent its being easily read and shall at all material times be maintained in good working order.
(2) In this regulation “all material times” means all times when the motor vehicle is in use on a road except when—
(a)the vehicle is being used on a journey during which, as a result of a defect, the instrument ceased to be in good working order; or
(b) as a result of a defect, the instrument has ceased to be in good working order and steps have been taken to have the vehicle equipped with all reasonable expedition, by means of repairs or replacement, with an instrument which is in good working order.
I've requested via a service request that my car be rolled back to the previous software version, on the basis that the speed display is now partially obscured (I can only see it when making a left turn or if I move to the left from my normal driving position). The readability of the screen in general is significantly worse, IMHO, and that's just after one drive out to the pub and back last night (to collect a takeaway, so within the rules).
I don't mind the interface but I've only had the car a few weeks so not really got used to the old one. One thing I have noticed since the update is the car seems to go into 6 hour sleep/online cycles since I've left it parked over the festivities. Is this normal? I didn't see this pre 48.30, but again only had the car a short time. I changed my password so the only thing using it other than the tesla app (also re-installed) is Teslamate.
Following a Full Power Off my car seems to have returned to only losing a few miles a night, might be worth a try.In these colder weather conditions, its quite likely that the car is awake for periods of thermal management. I knows ours does this - you can sometimes hear a quiet whine from the front of the car.
TeslaFi have a list of reasons why car may not sleep irrespective of TeslaFi being in use or not. My vehicle is not sleeping! / Knowledge base / TeslaFi
...in mine, the passenger seat.- you can sometimes hear a quiet whine from the front of the car.
Same for me... EDIT: Actually, mine is doing it more frequently, so maybe it is temperature related? It's pretty consistent though, which is a point against it being temperature related.
I'm on 48.30 and there's definitely something weird going on, I haven't moved the car for days and there shouldn't be anything waking it:
Here's the last 24 hours (which have been far milder than the previous few days):
