Artiste
I get the “80% recommended for daily driving” message.Do you get the 80% warning on your car? If not then it may be battery-chemistry specific, and not apply to your car
I interpret it slightly differently. Just as previously it was advised to not leave the battery sitting for extended periods at greater than 90%, the recommended is now 80%. This is consistent with what many posters had been recommending previously but I mostly set the car at 90% since that was the Tesla recommendation. I really don't see the 90% to 80% guideline change as meaning if you need more than 80% and plan to use the car that going above it will damage the battery. I can add 10% in an hour and rarely (never) have an instance where I need more than 80% on an unplanned journey. I understand this won't be the case for everyone.Mines change to 80% for daily on the charging chart thing. I'm surprised it's not been reported more widely as in essence they're reducing the daily range by 10% and the subtext is using more than that can/will damage your battery in time.
I'm finding it REALLY hard to resist charging up to 90% when PV is regularly exporting to the grid after house demand is satisfied, batteries are full, the Fiat is at its recommended 100% but the Tesla is now stopping at only 80%.I interpret it slightly differently. Just as previously it was advised to not leave the battery sitting for extended periods at greater than 90%, the recommended is now 80%.
The other day mine was set to 80% but in the morning had a notification saying charging complete at 84%, not happened before, alway stopped at the set amount.Mines set to 75% and has been plugged in a few days and slowly overcharged up to 79% with a little blue extra bit on top. It’s not exactly cold, so curious what its doing
Yup, Joe mode is actually working correctly for the first time in mine since I got it in March ‘21.I know it was mentioned earlier in this thread, but I'm just checking I'm not mad - the bings, bongs and indicators have got quieter in .8.
I have two regular passengers, and both have commented on this unprompted.
This is on a 2020 M3P...
I prefer it mind, other than the indicators![]()
I noticed yesterday using SatNav the voice guidance now only comes out the centre speaker, not sure if this was a bug or not.
@AnthonyLR naughty step for me I’m afraid. …write out 100 times; “I must not use AP on B roads”2023.26.9 downloading now. @Dilly ?
Re: the discussion about AP and speed limits. Has Tesla ever said why AP doesn't automatically adjust speed when it sees changing speed signs or at least provide an option to have it behave that way? Coming from a car that did do that, I thought my Tesla was broken when it carried on sailing along way above speed limits![]()
Before you use Autopilot features, customize how they work by touching Controls > Autopilot.
- Set Speed: Choose whether Autopilot engages at the currently detected speed limit or your current driving speed. Touch Controls > Autopilot > Set Speed and choose either Speed Limit or Current Speed.
- Offset: If you choose Speed Limit, you can specify an offset by touching Set Speed Offset. You can choose Fixed (the cruising speed adjusts by a specific amount on all roads) or Percentage (the cruising speed is adjusted as a percentage of the road's detected speed limit).
I press the 'speed limit' value (say 50 in the red circle) then the car slows/changes to the pre-agreed limit above that which is outlined in the offset section.Yes, I have selected "Speed Limit" but I believe that may be what it engages at rather than what it keeps to ? However, I see I missed a few posts on the previous page about this, seems there are some dependencies on how it will behave.
