Took delivery today (Silver P3-, Brisbane, 4882XX). They definitely want you to just take the car and leave. Delivery specialist opened with something along the lines of "I don't really know much about the car, I'm just here to help you get in, comfortable, and out on the road".
Random thoughts:
Driving - pretty much what everyone else has said. If I had to pick a word to describe it, I'd go with "smooth". Was worried that a car with this much power would feel uncontrollable/difficult to finesse, but it's not. If you want to creep along at 1kph it'll do that. If you want to take off like a rocket it'll do that too. And it never confuses the two. The throttle response is perfect.
Driving at night - had a moment of panic when I looked inside the car and saw that none of the dashboard instruments were lit up. Then remembered that the car doesn't have any. Rear mirror visibility also felt a bit limited, which for whatever reason it didn't in daylight.
Major issues - after about 50kms a 'Charge port door sensor fault' warning appeared on the screen. Charge port seemed okay when I got home, although the up/down action was quite jerky. Now it no longer opens/closes under its own power (though luckily can be manually opened when unlocked).
Minor issues - submitted a few (all legitimately minor, aside from the charge-port thing):
Using the screen - it's fine, feels natural (though I need to learn what some of the icons mean).
Using the stalks - hit the gearshift once when I meant to indicate while traveling at highway speeds. The car beeped at me and nothing else happened. My wife did the same while driving at a slower speed. No beeps (or anything else).
Track mode - Edit: nevermind; car must be on and in park and then 'Track Mode' can be enabled just fine.
Fog lights - Edit: fog lights can be used when the car is on and in any gear; not usable when car is off (unlike all other lights, which
can be used just fine while the car is off).
Software version - car delivered with '2019.32.2.2 (da05838)'
Stereo - definitely quite good for a car, though would rate it slightly below the hifi at home. The default balance put the sound a little too far forward for my liking, shifted it back a bit.
Range - Brisbane to Sunshine Coast with a brief detour for lunch took 23% (80% -> 57%).
Extra nitpicky - the media player forgets your position when playing off USB media if you reboot the screen (which I did to see if it would clear the charge-port warning...which it didn't); this issue bothered me so much on other platforms that I wrote a custom media player app for Android Auto specifically to get rid of this quirk.
Anyone else notice a significant increase in battery drain on their phone after pairing with the car?
