Nah, you should add spinnersThe aero caps are pretty lame looking. I've taken them off and added lug nut caps - much nicer underneath
Yep, may not event be supply chain related, could be because of ongoing readiness for Model Y assembly line.But I agree that we are only speculating on the reasons for delays in particular models.
The Australian configurator shows the fiction that an order now will result in a “late November” delivery. Good luck with that.But I agree that we are only speculating on the reasons for delays in particular models.
Possibly no help but I was in the same boat as you.The Australian configurator shows the fiction that an order now will result in a “late November” delivery. Good luck with that.
I’m on the verge of pulling the trigger. I have a real dilemma between waiting for a white interior that might never come, or concluding that exiting the fossil fuel economy is so important it takes priority over personal aesthetic preferences.
Oh!!, good point which I hadnt thought of. I was thinking of the headlights on traditional vehicles.There are no bulbs, just LEDs and reflectors, the beam pattern is very flat and the difference between high and low beams is which emitters are turned on. Apparently the Model S & X in europe can use gps location to adapt the headlight pattern / aim to the side of the road you are driving on, so I assume the model 3 would be able to do the same.
Great idea, then connect the spinners to a generator and you have a perpetual motion machine!Nah, you should add spinners
doesn't want me to install it now
As someone who may want to install this sort of thing, maybe you can explain why? It seems like a great convenience to me, although I understand that one would need a hand free to use the phone to unlock the boot anyway.
Is that the reason?
Do not just reply on the word heavy duty extension cable. Even if its 15 amp cable check the copper size. As mentioned earlier it should be 2.5mm. Most extension cables are not designed to be run at a full rate for long periods. So just because its a 15 amp cable itmay not be suitable.
Oh yes! Worth a shot, but Siri has not been reliable enough for me!
Is that the reason?
is it more efficient to set the climate control to auto
How did you find the glass roof in that heat?In the Outback when its i.e. 40 degrees
