zip compress them first. If you have GPS data in them (which is really helpful) and would rather not let eveyone see that, send it to me on a private conversation. I will remove the GPS data after I calculate distance.the website doesn't like .csv files.
Only do this though if you don't mind leaving the GPS data in. If you pull the GPS beforehand, do us a favor and send us the version with GPS. We'll remove the GPS after we compute distance.You can also create excel files online and post links.
Pretty sure CL600 has an old drive unit. 12 June would definately be an early build date for the new drive unit, in fact you may have gotten one for testing before they went into mainstream production, although 12 June is a Monday and sometimes they refer to the whole week as the Monday production date.
Emailed it to him earlier last night. I know the eagerness!!
I don't know much about CAN logging. The basic power, velocity and GPS data would match he PowerTools and Dashboard data. Car reported torque and current amperage would be a nice addition. Might be nice to know the torque and or power split between the two drives. I have also seen throttle position, which would mean we could add non rollout starts.Any preferred format for CAN logging?
I have a Panda set up to log on 3 busses, and also have a LELink BT dongle I use with TMSpy (though it seems to drop frames).
I will likely get around to writing an app to do some better real time logging, but want to make sure the format and parameters logged are useful...
Yes it uses the web API. You can get a one day code to try all the features by asking the developer, but you'd need to know which date you'll have the device.How does Dashboard for Tesla work? Does it grab metrics from the API? Is it accurate?
I am an iPhone user but can snag one of the S8s from work to try the app once I get my car to add more data points.
Thanks for checking. I'll make them consistent in the next update.@Krash, quick clarification: @Chasedrgc1223 car's data is listed under "Uncorked" on the table above, but in the zipped files showing the individual runs, it says "Corked". Also, how do you know if it's corked or not from the data? Is there a flag somewhere?
