Why you using rollout? Feels like it is cheating
I don't use any of the given times. I only use the raw runlog dataKrash...the time I gave you (5.125) with my S85 was not with a roll out. It was just straight pedal to the metal.
I used to just fit the numbers based on whichever of several guessed formulas fit the empirical data best in a regression.How are the implied torque numbers calculated? And where were the published torque numbers picked up from? The only motor specification I can find is on the Model S User Manual and it says the motors are derated to 250Nm on the Base vehicles and are 330Nm for the small motor and 675 Nm on the large motor for the performance vehicles.
That formula for wheel torque should be:=(wheel radius*(weight in grams*torque acceleration)^0.5)/gear ratio
Bitter owners are definitely bitterIt legit boggles my mind that an S75 RWD is so much faster than my S85 RWD.
Bitter owners are bitter![]()
I made a mistake:That formula for wheel torque should be:
τ = r ∙ √ [m ∙ ΔP/Δt]
Where:
τ = torque at wheel, in N∙m
r = radius of wheel, in meters
m = mass of vehicle, in kilograms
ΔP/Δt = time rate of change of power, in kW/s
Then, dividing the wheel torque by the gear ratio gives the total motor torque.
